ridgerambler
I have a fertilizer unit on my Farmall 140 and when using it tends to "grind up" or pulverize the fertilizer which eventually seems to clog up the rubber discharge hose. Wonder if anyone else has had that problem. I usually set the flow gate towards the low end to keep from putting out too much flow (even open all the way, it tends to grind, but not as bad). The discharge hose is the common after-market rubber hose sold by Ag Supply and others for the farmall (use same hose for my 180 planter). The star wheel works good, but has some play in the shaft, but I don't think enough to cause my grinding problem. I am using 10-10-10 primarily. Anyone with similar problems or suggestions?
