Farmal C Front Wheels Bearings
560Dennis
Location
Madison,Ohio
Anybody know if there are aftermarket taper roller bearing numbers for these bearings . Like a Timken number for the set the inner and the outer bearing ?
The numbers I have on my wheel bearing list for a Farmall C are: Inner Race 15250 (IH P/N 54630H), Inner Bearing 15118 (IH P/N 54631H), Outer Race 09196 (IH P/N 43440D), and Outer Bearing 09074 (IH P/N 13823V). These numbers were cross referenced from an IH Bearing book. I hope this helps. Ben
Carefully look at the old bearings,there should be a number on them. Or take the old bearings with you as a sample to your local NAPA. They can match and supply bearings. They may even have a book with them listed.You would be surprised just how muck NAPA can get for your old tractor.Bearings,seals,ignition parts,carb kits,OH kits,filters.........You should order a parts book. BTW,be sure to check out the good folks here at YT,they sell parts,too.
