TractorLinks.com
Show Parts for Model:
H PTO
Doug-Iowa
05-16-2018 11:25:27
I'm considering removing the PTO from my H. I've long since stopped using it for real work, its just my tractor ride tractor now and I'd like to build a custom platform on the back. Removing the PTO will give me an additional 8" of space. I'll save it in case I want to put it back. From the drawing it looks pretty simple, just pull the unit out and fabricate a cover and seal for the opening in the rear end. Any worries with this plan? It looks like the transmission counter shaft is supported by a bearing so it should continue to operate properly without the PTO shaft in place.
rustyfarmall
05-17-2018 06:12:22
 Re: H PTO in reply to Doug-Iowa, 05-16-2018 11:25:27
Seems like I've heard of using a steering bolster top cover?
DeltaRed
05-16-2018 18:10:42
Make cover plate from 1/8 steel.I make em from 14 gauge or 1/8" when I remove the belt pulley drive/gearbox.
DR. EVIL
05-16-2018 14:58:34
IH made a block off plate for PTO's, Doubt CIH/NH handles them anymore. Might try a salvage yard for one. They're in the parts book.
Goose
05-17-2018 16:29:56
 Re: H PTO in reply to DR. EVIL, 05-16-2018 14:58:34
Or try ebay. I've found a lot of H parts there.
Jim MA
05-16-2018 11:39:35
You have it, just remove the PTO unit and replace with a block off plate / gasket /rtv. If you do not want to drain the oil you can park the tractor on a sufficient enough slope and remove and replace.
Doug-Iowa
05-16-2018 11:45:15
 Re: H PTO in reply to Jim MA, 05-16-2018 11:39:35
Thanks!. Great idea on pointing it down hill, I have just the spot for that.
