TractorLinks.com
Show Parts for Model:
Alterntor on W4
Klein Rot
05-16-2018 01:40:41
Will a Delco Remy 35 Amp 6Volt 10SI self exciting alternator fit under the hood of a W4 tractor.
fbh44
05-17-2018 02:57:54
 Re: Alterntor on W4 in reply to Klein Rot, 05-16-2018 01:40:41
My Delco 10SI fits under the hood of my 1950 H with a dollar-bills worth thickness to spare. But it does fit.
tractorguy2
05-16-2018 06:59:47
I have done it with Farmall H,M,C,300,and 400. The alternator fits under the hood fine. You will have to make a bracket or buy an alternator bracket made specifically for a Farmall H. Steiner tractor parts sells the bracket.
tractorguy2
05-16-2018 07:12:18
 Re: Alterntor on W4 in reply to tractorguy2, 05-16-2018 06:59:47
I just checked YT. they only carry the universal bracket. That will not work. You need the bracket made for a Farmall H. Steiner tractor parts might be the only one that has it.
BarnyardEngineering
05-16-2018 06:24:37
I think gene's "t" key is broken, and the response should read:
"If you can't make a bracket, usually not."
To me that means, if you try to use the factory mount like you would on an M, it will not fit.
There are conversion brackets available. You don't need to make one.
However, the Hitachi 14231 alternator is roughly the same size and shape as a Delco generator, maybe slightly smaller, and is a much easier fit.
gmcdeadhead
05-16-2018 03:57:40
I bought the hitachi alternator from Charlie’s repaire. I will fit under the hood with no problems
John M
05-16-2018 03:23:05
I have the 1 volt version of a 10SI under the hood of my I4.
gene bender
05-16-2018 02:11:31
If you can make a bracket usually no
Klein Rot
05-16-2018 04:20:26
 Re: Alterntor on W4 in reply to gene bender, 05-16-2018 02:11:31
How do you mean Gene it doesn't fit or only with a new bracket
DeltaRed
05-16-2018 06:42:53
 Re: Alterntor on W4 in reply to Klein Rot, 05-16-2018 04:20:26
If you use the original generator bracket,NO it will not fit.If you make,or buy a custom bracket,yes it will fit nicely.Then you Will have to get a new different length belt.I've done 6 H/M,400..... tractors. makes a nice outfit.
