TractorLinks.com
Show Parts for Model:
Farmall A seems stuck in gear
Stevie J. Mote
05-15-2018 20:37:51
Hello I have a Farmall A been setting in my buddy driveway for few years now. When we parked it we pur it in nuetral. We had to roll it around some. Went to move it the other day and seems stuck in gear although the gear shift is in neutral. What you all think could be and possible fixes. Thanks !
old
05-16-2018 08:24:08
 Re: Farmall A seems stuck in gear in reply to Stevie J. Mote, 05-15-2018 20:37:51
So has some one put it in gear while it sat?? If it was parked out of gear and no one put it in gear I would say it has rusted up from sitting and condensation and maybe rain has entered the transmission and rusted things up Seen it happen to a number of machines over time. Also could be the brakes rusted up
BarnyardEngineering
05-16-2018 06:22:02
It is much easier to remove the entire top cover of the transmission on an A, which includes the shift tower and shifter. Then you can look right in, see where the gears are situated, determine if things are full of water and rusted to beat the band, or what...
It is also possible that critters have made nests in the brake housings, done plenty of business up in there, so now the brakes are rusted and seized.
khouse6
05-16-2018 06:10:12
sounds like it is locked in 2 gears. my C farmall does this. block the front wheels, jack up one rear . will it turn? if not, you will probably need to remove the shifter lever, look down inside and see if the rails are lined up. the slots that the shift lever goes in , should line up with each other, to be in neutral. if not move them so they align
Stevie J. Mote
05-16-2018 05:26:56
Hello Gene. I can push the clutch pedal and the gear shift is in neutral but still wont move
Charlie M
05-16-2018 06:34:08
 Re: Farmall A seems stuck in gear in reply to Stevie J. Mote, 05-16-2018 05:26:56
Maybe the starter is stuck to the ring gear. It happens on Farmalls as ring gears get beat up over the years. If so its a simple fix - pull starter, move flywheel a small amount and reinstall the starter. If that is what is happening it will happen again over time until you put in a new ring gear.
gene bender
05-16-2018 02:09:34
when you push the clutch in does it move
47fivewindow
05-16-2018 17:30:04
 Re: Farmall A seems stuck in gear in reply to gene bender, 05-16-2018 02:09:34
When I was about 12 I was practicing my "speed shifting" on my dads parked Super C and got it locked in two gears. Dad went to his grave without figuring out how that could have happened.
FastFarmall
05-17-2018 11:32:07
 Re: Farmall A seems stuck in gear in reply to 47fivewindow, 05-16-2018 17:30:04
Fivewindow, well at least that was easier to work on then the M.
