Oil cooler on 560 d
Hayfarmer
When I asked about removing the oil cooler due to a leak, one poster said it was easier to remove the side rail to get to it. It appears this would be easier than trying to fight it out of it's spot. If I put a big jack under the oil pan, with a wood block under pan, can I take pressure off of engine mount and also lift enough to unhook wide front? Or is there a better way?
Don't put the jack on the oil pan, go back just a little to the center section and place the jack and blocking there.
