farmall 300 pto seal
dewy
what is the correct seal number..gave local seal dealer numbers off case ih parts diagram and was way to big for shaft..also is the seal housing hollow ...when taking old seal out the outer face came out with seal or that was the seal..must of been original was thick with felt..also does the gasket supposed to have 3 holes or 6 the gasket that was on the housing only had holes for bolts......thanks dewy
When I replaced mine a couple of years ago, the seal was almost hollow and only had the seal lips in it. The old seals were completely filled. I used two seals instead of the original one. I put one on top of the other. I do not remember the gasket when I did the seals.
so the housing is hollow ,theres no face,lip or anything..is that correct an still curious about gasket ..also where is the pto housing on the part diagram i think i gave the seal guy wrong number.........thanks dewy
i found it ,,its under speacial attachments,i definetly gave him wrong number..still curious about gasket
sorry sometimes i ask some dumb questions..just kind of looked like it was blocking oiler holes but i guess it lets it in groove...sorry sometimes i think im just shot out.....dewy
