Youngin 7140?
Ordered a new gasket from CIH. Ordered head bolts from A.M and picked up CIH torque procedure. Was not impressed with the o-rings in the gasket. Thanks for the reply. I posted in the subject.
Hopefully you have better luck with head gaskets from Case IH. I sure don?t if the part number is J938267AM it a aftermarket head gasket which I?m about 99% sure CNH is getting from Reliance.
I have rebuilt probably 40 - 50 of those engines and they nearly all will leak coolant on the right and oil on the left eventually so I started putting a bead of gasket elimator on both sides of the gasket down each side , never had anymore leaks , I'll probably catch heck for saying that ,it worked I worked at Casih dealer 17 years
