Hello all! Before I start I?m going to apologize now for the log rambling post. Also hope it?s posted in the right spot. Thanks!!
I had just recently traded my 51 8n for a 66 b414. Guy I traded said it didn?t have high range or 3-4 gear. Well I got it home, started tearing it apart. Found half the gears on the cohntershaft ground off, the upper sliding gear bearing was toast and 2 of the shift arms were also ground off. A friend of mine pointed me to an old ?tractor junkyard?, more like a gold mine. I went there and bought a used casting with all the gears from the bellhousing to the axles. It was a 63 body. I swapped the good gears and shafts into my casing as the 66 had the larger brakes. I also put new seals, fluids, clutch friction plate, and pto/clutch housing in as well. Got it all back together, fired it up and it wants to drift forward when in neutral and the clutch depressed. Also I can?t get it into high range, just grinds away. When i do get it into gear in low range it wants to take off or if it?s in reverse it will just bog down till it stalls.
Any one have any suggestions or insite? I?m a mechanic for FedEx and work on Mercedes sprinters all day long so I shouldn?t be having this much problems. This tractor is a screw driver compared to a Mercedes which would be 20v drill..... haha
