Farmall 656
Today, I put on my Vermeer TS 20 tree spade for the first time onto my 574. I couldn't figure out why the hydraulic system on the tractor was not working the different valves on the tree spade. Next I would
engage the hydraulic lever on the tractor and then I could activate the hydraulic valves on the tree spade. My question to all of you is this: IS there a way to change the system on my 574 to allow
the tree spade to run on the 574 hydraulics with out engaging the hydraulic lever on the tractor? Currently, I would have to engage the hydraulic lever with my foot and then run the levers on the
tree spade. When I push the hydraulic lever all the way down or in the locked position, I believe the system is in free flow without pressure-which will lower the cylinders not raise them. What am I
missing on this system to allow my to run this tree spade more efficiently without looking like a gymnast.
