Jeff Nania
New User
I hope someone can help me out. I have a 464 IHC gas tractor.
#1 and #2 are not firing. They are however getting spark and in the correct order. Our local tractor mechanic and I went through everything twice. When there was any question we replaced the part. It appears as though the cylinders that are not firing are getting some fuel maybe not enough. We have checked the compression and it is good. New plugs, cap, wires, coil, carb overhaul. Rocker arm cover off all seems in order Any help would be much appreciated spring is coming on fast and this tractor has work to do.
Jeff
Jeff
