I think I have a worn differential shaft on a ?43 A. I just replaced the differential and final drive seals. Now I am seeing oil leaks at the final drive so I tore it apart again. Noticed a little oil on what is supposed to be the dry side on both seals. I double checked that the seals were installed the correct direction. It leads me to believe that either the oil seals from another well known tractor parts website were faulty, or that the shaft itself is worn at both places it makes contact with the seals.
I can?t tell for certain if the shaft is truly worn. Nothing looks out of the ordinary. I?m thinking I might try a speedi sleeve that is supposed to fit with the oil seals. My question is if the shaft is not worn that bad with a speedi sleeve on, will it cause any problems with the performance of the seal?
