I am having an issue where my tractor suddenly starts sputtering like it is starving for fuel and dies. On a new day when it has not been running, it will start fine and run perfectly normally for about 20 minutes, then suddenly it will sound like the engine is running out of gas. I put in the clutch and play with the choke and it may or may not start running normal for a few seconds and then repeat the same problem. If it completely dies, I can restart it and the same problem happens again in a couple of seconds. I have cleaned out the fuel bowl and the fuel bowl filter and the screen going into the carburetor. Does anyone have any ideas and suggestions?
Thank you.
Thank you.
