Phil Tibbetts
Found an I-9 McCormick Deering with hand clutch to go look at. Wondering what kind of problem parts will be. Owner says the hand clutch was not releasing as it should releases but slow. Any thing I should be on the lookout for? tires are odd size 14 x 34 rear 7:50 x 18 inch fronts . 1947 year. Always liked the look of these old monsters. 334.5 ci engine so don't know how scarce parts would be. Any info someone has would be appreciated. thanks
I9 is the same engine as W9. The front tires are the same.The drawbar assy,rear wheels and seat are different than a 'W' series.I have an I9 here.
that is the regular gas engine found in the W9, 335 cid. the wd9 had the 335 also, supers had the 350 cid. no supers in the gas model.
Parts are very hard to find, New sleeves and pistons will run $2500. Main bearings if you can even find a set will run $600-700. Gasket set $400.
