Farmal B head
I have one laying in my shop but would have to count head bolt number on it. My e-mail is open
all A,B and C heads are 9 bolt but there are different designs in the combustion areas. There were several designs also for pistons dual fuel and altitude.
Where are you located - I have a good head for CHEAP. Its off a 47 Farmall A, so it wouldn't be the correct date code, but should work fine for you... I'm in Lisbon Maryland.
Thanks all,, I got one off some one on here that saw my post,,it's on the way now, this is for my grass clipper.
How do you like that aftermarket seat? I've been thinking about getting one for one of my tractors. Review?
I have a parts B with an aftermarket seat on it but it is a bit on the odd side. Has a spring and shock under it and a sort of warp around back rest. Frame is all that is left of it but could be fixed up pretty easy
