D282 Head Gasket
Algr6
New User
Hi.
I am getting ready on finishing up a repair on a Hough H50 with an IH D282 engine. The head gasket removed was an aftermarket Felpro, which was an all metal gasket with integrated rubber seals for the fluids. The gasket set I have is a typical fiber based gasket with integrated fire rings. It is listed on the packaging as for a D282, but I would like confirmation that it really is the proper gasket and not a copy of a copy of a copy, etc. Any feedback would be great. Thanks.
I have 2 gaskets kits INTERNATIONAL 173141R93
-------18 gaskets FEL-PRO INTERNATIONAL 601509C1
these gaskets should be for D282
that is the correct one. i have used more of those than the metal ones with good luck. i spray the gasket with high tack sealer and do the torquing in four steps , actually 5 steps ... get it warmed up good then the final torgue to 120 ft.lbs.
