Steering Shaft Bracket
Working on a 1955 International 100 Farmall. I've removed the steering shaft bracket for restoration. Does the brass bushing inside the bracket suppose to rotate with the steering shaft? Being that there is a grease fitting on the bracket would imply that it does. This bushing is frozen solid. Thanks. See the picture or video for details.
Reinstalled Instrument Panel
No. Thhe bushing is pressed into the holder.The bushing has a hole that is lined up with the hole in the holder for grease.
Ahh..I see now; but the holes are 180 degrees out of alignment. Should be a simple matter of drilling a new hole.
