Gas-diesel injectors
Can anybody answer how interchangeable the injector nozzles are from the MDs/W thru the 450s? I know the bodies have different angles to the injector lines and some nozzles are adjustable. But, can different style nozzles be mixed on the same motor with minimum fuss?
Thanks, Chris B.
No, you are not suppose to mix injector types on the same engine. The manual states this. If I recall correctly, it states this will lead to a rough running engine. The manual also states when changing to the new style open face injector, the fuel CC delivery needs to be reduced to keep the same HP setting.
