2001 loader brackets
So I bought a cheap 2001 loader that is missing the front brackets. I know it is going to end being hand built as the places I have tried don?t have any. I am still looking so if anyone has a set for either a 560 or a 400 let me know. I have seen people bolt it right to the area a weight bracket would go on a 560 but would rather see any other ideas or thoughts. It is still froze down at the place I bought it from so I have time to think about what to do.
That makes the most sense, to use the weight bracket holes, Use the back, of a weight bracket for a pattern to make your holes.
My dad had one of those loaders we put on the 706 or the 504 . the front brackets were heavy angle iron about a foot and a half long that bolted to the tractor side rails then you drove into the loader so the brackets went under the bottom channel of the loader. for the 706 the angles were down and the 504 the angles were up. grandpas 560 had the same setup. harvester once said that loader fit 2001 different model tractors.
Depending on what tractor it came off of, you may have a problem on the back end of the frame. There were about 5 versions of the frame for different axle housing shapes and height off the ground.
The 400 and 560 used the same rear attachment. So you will either be good to go with both or will have the same problem with both.
Yeah some one has used a gas wrench on the back also. It was the
correct length for the 560. I have had two of these loaders before. I
am looking for the manual that I used to have. I don?t think that I will
bend steel for the front. I have just a tad over scrap for in it. I saw one
the frame was cut off real close to the up rights and someone mid
mounted it. I will not.
