I am working on a J4 mag given me without knowing if it is good. I cannot find the beveled 2 teeth on the rotor. I have looked at it for an hour and simply cannot see where 2 teeth are beveled. There is a nice raised mark on the drive gear but nothing on the rotor teeth. Could the teeth have worn off the bevel? Could it be another rotor that uses the terminal to align with the drive gear?
I need for someone to look at one with beveled teeth and tell me where they are relative to the terminal looking at it from the teeth side at the 12 o"clock position.
Also I was unable to remove the 11/16 nut on the lug end. Is there a trick to do this? If I hold the lugs and turn the nut, it just winds up the spring inside and I stopped before it loosened. I assume it is a right hand thread.
