Oil in Radiator on Farmall Super MD
Eddie V
Just got a Smd running and runs fine doesn?t overheat no coolant in oil operates normal but has some oil in with coolant
I am thinking possible bad head gasket or head?
On the front edge of the head (right corner) is the passage of lube to the rockers. If the head gasket fails there, there would be pressurized oil escaping either outward or inward. Jim
