light switch
Have no idea what the engineering specs are but from my experiences with a number of 06,56 and 66s
They are fused at either 15 or 20 amps.
The max stock loading that I know of was 5 4411 or equiv 35 watt sealed beam lights. This is about a 15 amp load.
Extended use at this 15 amp load will eventually overheat the battery terminal causing it to rust (they are made of steel not brass) resulting in a poor connection which causes even more heat.
If you plan to add any additional lights, run them from a relay.
One expensive solution is to change to LEDs. Hope this helps.
(quoted from post at 14:08:47 04/04/18) Have no idea what the engineering specs are but from my experiences with a number of 06,56 and 66s
15 amp is #14 wire
20 amp is #12 wire
I was putting led's on since the others don't work and the wiring is in poor condition. A 24 inch light bar in front and in back. Thought maybe I could use the original switch for that load and skip the old 4411's. They are like holding a candle out there for light compared to the led's.
I had forgot they had a 15 or 20 amp fuse in the light line. Thanks.
