Swapped the narrow front on my 1939 M over to an original IH wide front with setback plate.
Never really had the "death wobble" but it did wander pretty bad.
My vertical bolster shaft is worn pretty bad where lower bushing rides, which is messing up the gear lash, and it's worse now, without the thrust from the tricycle front.
Bushings will help, but need to get a new shaft, or build mine up and turn it back down.
Anybody know if you can buy a new one?
What diameter should one be on the large journal?
