I recently purchased a 1953 Farmall Cub in very good running condition. I will say that I am NOT a mechanic, but I do like to tinker with these old tractors.
This tractor has always started and ran fine. I had it running the other day and all of a sudden it started missing real bad and finally quit. I got it to start
back up but it was missing pretty bad, almost like I had water in the fuel. I checked for that and the fuel seemed to be OK. After tinkering with it a while, it
just wouldn't start. After replacing the points, plugs, condenser, rotor and distributor cap, I got it to start and it ran good for about 30 seconds or so and
then quit, and now it won't start. Can any of you IH guys out there give me some advice as to what to look for next? I took a spark plug and plugged it in to a
plug wire and laid it on the cylinder head and turned the engine over and I didn't see any spark. Is it possible that I may have a bad coil? If so, is there any
way to check the coil. Can I try using just any other 6 volt coil, or would it have to be the IH style coil that is on the tractor now? I'm just stumpted as to
where to go from here?? Thanks so much for any suggestions!!!
