Farmall a horn
460anger
This a that I am working on has a horn mounted under the gas tank looks like a factory mount If not someone did a nice job making it any input?? Thanks
If you go digging around in the parts books for your tractor every once in awhile you find something in the back pages. For my 1977 CUB there is an option for a horn. It is a low note Delco horn and mounts down by the lower right corner of the radiator. The horn button mounts on the steering wheel bracket just up from the gas throttle. You could very well have a rare little item on your tractor. Don't break it !!
It does work the button is unhooked just jumped it to the battery the button is like you said up on the steering shaft it does have a tag on it believe it reads the electric lite company Toledo Ohio
