I know this has been talked about a few times before.
Been working on my fathers 544 farmall TA
The tractor seems to be in the TA mode and not the direct drive mode.
I have a extreme gut feeling that every thing from clutch to TA is out of adjustment.
there are a few issues such as slack in the connecting pins and linkage points, but mostly just all needs adjusted
for example the TA cam that moves the clutch cam does not make contact and Im sure this has been a problem in the past because someone has welded a bead on the TA cam to make it touch in the past.
I worked with it some yesterday and its linkage operation confuses me beyond belief.
Is the TA cam supposed to raise up on the the clutch cam to engage the TA or does it hold it up and when put into the direct drive position hold up the clutch cam HELP
