International 350 Utility Hydraulic Hose Replacement
DougieD
New User
I need to replace a couple hydraulic lines on my 350 Utility, but want to make sure I do it correctly. I have couplings that look like the ones pictured here. Am I correct that my hydraulic line's 1/2" pipe thread end screws into the bottom of this? I have tried to remove this coupling from the existing hose, but it's on there awfully tight. I'm thinking I might have to put it into a vise to get it off, but want to make sure I won't destroy something if I do, and that I don't have to just get a new fitting to attach to the hose. If the latter, what fitting to I need - what's this called? And when I attach the hose to it, do I need any teflon tape or anything to seal it?
Thanks for any help!
DD
<image src="http://forums.yesterdaystractors.com/photos/mvphoto13041.jpg"/>
If I am reading correctly you want to remove the left half from the right half. If so I would use 2 deep 6 point sockets and a long ratchet or breaker bar on each. That should prevent any damage that might be done by putting them in a vise. IMO
Also if they are regular pipe threads I would use hydraulic sealant or Teflon paste, don't like to use the tape on hydraulics. It can really cause problems if it gets lodged in a valve or pump. IMO
