I'm working on my Pettibone fork truck again this winter. Bought a carb kit for it a while ago, and am finally getting into it. See pics here: https://imgur.com/a/yOqwm
I'm having a heck of a time searching for parts online. I have a full set of manuals for this thing, including a separate parts manual for the UB-240 power unit that is mounted on this fork truck.
All the IH parts numbers in the manuals are out of date for this new age of online searching, absolutely none of them come up. I've usually had good luck trying to search on the NAPA website for part number interchange, but ziltch...
It looks like at some point the carb and velocity governor were swapped out on this machine. All the IH numbers on the parts don't match the parts book.
The velocity governor as near as I can tell should be a 2800 RPM governor. I'm hoping someone here has experience with these old governors.
Do these units simply act like a rev limiter? There are two labeled ports on this governor, one reads "carb", the other one reads "to distrib". Both are blocked off on this unit, but there are vacuum ports on the flanges, so I assume this thing works off of intake vacuum?
There are various examples of these on eBay, some for silly prices:
https://www.ebay.com/itm/1971-Chevr...2707759225&_trksid=p2047675.c100005.m1851
I'm wondering how I make sure mine works, or if I buy an eBay unit, how I go about adjusting it? I assume these have to be adjusted with the machine under load? No idea... Hope someone here is familiar with these.
