I am adding power steering to a 300U. I have 2 priority valves here that will replace the safety valve at the right rear of the reservoir. Valve 1, 364844R3 has 3 holes on the side facing the reservoir but has the center top hole on the side facing the fast hitch valve plugged. Valve 2, 364844R4 has the same 3 holes on the side facing the reservoir but does no have the upper center hole on the side facing the fast hitch valve plugged. Anyone know which is the correct valve?
Also, the instructions indicate that I am to plug the center top hole in the mounting surface at the right front of the reservoir before reinstalling the remote valve. Looks like a standard 1/2" bolt will do that task, correct?
