Old weldor
I am looking at a 1941 m Farmall. Sheet metal is fair, the points evidently stuck in the voltage regulator and burnt the wiring. It was then parked
outside now the engine is stuck. The front tires are shot, back tires have good tread but are weather cracked. Has one set of wheel weights.
100 percent original still 6 volt with a generator. What is a fair price? Some of you will say scrap value but what is that as I know iron prices
have dropped. I intend to fix it not scrap it or part it out. Sheet metal is good except for a couple bent grill bars.
