ih 584 loader
Simply measure your cylinder both open and closed then contact the surplus center and they can get you what you need. or 800-488-3407
Hyd parts
Well, IH has sold many different loaders over the years. There are at least three I can think of off the top of my head that would fit a 584. Can you be more specific?
Also, what is the reason you need a new cylinder? Unless the rod is badly bent or badly pitted, a hydraulic shop could install new seals and packings in that cylinder for much less than the cost of replacement, even if you have to drive a couple of hours to the nearest city.
one cyl. missing from loader other being packed it's 28 inch closed has 20 inch stroke 2 inch bore 1.50 rod
With that info you should be able to call the surplus center and get either a matching cylinder or a match set of cylinders. I need to do that on my IH584 loader because I bent one cylinder but have not saved up the $$ to do so yet.
When I have the $$ I plan to up grade the cylinder but going wit ha larger shaft size so I do not bend another cylinder.
can i send u pic. of my loader see if same one u have don't know what it is need your email address don't know how to send them any other way
