nope your thinking of Distillate tractors thermosiphon sure don't need help heating up you ever see a cub with shutters on it?(quoted from post at 03:15:47 04/12/17) The old tractors thermosiphon systems used shutters to obtain the temperature you wanted. Permanent anti freeze will not separate but the old methanol anti freeze could freeze if you didn't keep track of it.
ark check overflow tube for blockage, My 10 20 had same issue.(quoted from post at 20:59:20 04/11/17) Started a couple of tractors today that don't have water pumps and they were running hot after a short while. Can the water and antifreeze separate during the winter causing a block and keeping the system from circulating? thanks Mark
