DeltaRed
You posted/answered below about a plug to replace the little plastic 'thingy'.exactly what does it change? do you loose the manual steering option when te engine is off? Does it make it steer easyer?I',ve seen the plug in privoise kits but didn't know what it was for.Please explain. Thanks,Steve
It go?s in the TA Houseing lower right corner where the MCV mounts you will loose manual steering no chances of leaking through steering check valve with that not in in there you should not have any steering and ta shouldn?t work
