Linkage Rod - What does it fit??
RTR
Just curious what this linkage rod fits. I'm thinking a rear mounted disk turning plow for either a Farmall Cub or a Farmall A / Super A style tractor. Haven't determined which one........maybe it fits a different tractor and a different implement. It is approximately 72 inches (6 feet) long.
(quoted from post at 21:45:01 03/08/18) Just curious what this linkage rod fits. I'm thinking a rear mounted disk turning plow for either a Farmall Cub or a Farmall A / Super A style tractor. Haven't determined which one........maybe it fits a different tractor and a different implement. It is approximately 72 inches (6 feet) long.
Pictures......
From any of assorted IHC old equipment. From a plow, to a binder, used often to connect a hand lever to a moving joint. We had
several on the farm I cut them up and used them to make go-cart linkage. Dad never got excited about my "use" so they were not
missed. I think at least one was found on the 2 row cultivator on H an M tractors. Jim
Thanks Jim. I need to see what the plow linkages lengths are to rule those out. But they might all be the same part number from cultivtors to plows to binders.
