AMD tractors in australia
Tomsy
New User
I am looking for info on a Farmall AMD tractor in Australia. ID plate says
SAMD AMD 3047
1595
Not much info from me, The engine may be a British direct start diesel instead of the US gas start type. There is a poster (Sad
Farmall) from down under that can help. Jim
(quoted from post at 11:15:59 03/05/18) I am looking for info on a Farmall AMD tractor in Australia. ID plate says
SAMD AMD 3047
1595
Look in the book about Australian IH tractors. I think the author is Sarah Galloway(maiden name0. It was published in 2013.
AMD or Super AMD? So far as I know, they are the Farmall versions of the AW6 and AW7 Diesel tractor.
I believe your numbers mean:
Farmall Super AMD followed by serial number, followed 1595 (max engine speed).
If Super AMD:
Engine data as follows:
263.8 cubic inch motor (4.3 litre)
Bore: 4"
Stroke: 5¼"
Engine Speed (Rated Load): 1450
Valve Clearance: .022"
Fuel Injection Pump: Manufactured by CAV
Direct Starting (With Glow Plugs)
It should have a Lucas 12V Generator (C45)
Gears slightly different from Petrol/Kero Farmall M, AM and Super AM - lower first gear.
I have been trying to get a friend to sell me his Super AMD for some time - no luck yet :(
SadFarmall
The BD-264 engine;a real husky English engine based on Super M engine C-264.Info on the picture
