IH TD9, where can I get diesel fuel filters?
pmarkel
A lady who I work for owns a TD9 that was her husbands' and I use it from time to time for odd jobs on her farm. Now it hadn't been run for some time until last fall and I am thinking a tuneup might be in order. Not having an owner's manual for it I do not know what diesel fuel filters it takes and where I can get them. It has metal cannisters so I cannot read any numbers on the filters without taking it apart which I do not want to do until I can replace them and prime it. Its an early fifties model I believe with the 335 four cylinder gas over diesel engine. Any advice on servicing this machine would be greatly appreciated. Thanks,
Pete
(quoted from post at 16:35:34 03/05/18)
The filters are available from your local CIH dealership as well as other sources. You almost need to open it up and see what is in there as a filter upgrade kit was available at some point which determines which aux. filter you may have. I don't have the numbers handy, but got them from the CIH website the last time I needed them.
Dan
Most likely the filters are still available through your local FIAT/dba CIH dealership.
Or aftermarket.
From the WIX Filters website...
<img src = "http://oi63.tinypic.com/2d94uwh.jpg">
Thanks for the help. I guess I'll pop the canisters off and see whats in there and go from there.
Wow, looks like a wide gauge 9 with a big old Bucyrus hydraulic angle blade....Good little machine, you can do a lot of things with that baby.......You should be able to get any filters for it at any CaseIH dealer or store having industrial and farm tractor filters...just ordinary IH 9 series Diesel engine stuff.
