I was USING IT TODAY AND HAD BEEN RUNNING IT FOR COUPLE HOURS WHEN ALL AT ONCE IT STARTED TO RUN POORLY AND SURGED the RPM and some times putting out some smoke. I thought maybe low on fuel but I checked and it still has a round a half tank. I did shut it down for a few minutes while I went and parked the 65 Ford 1 ton dump truck. Been using the 584 in the creek to load gravel to fix a big car eating mud hole in my driveway. I have some fuel additive so I went ahead and added some just in case it was water or such. I'm thinking maybe fuel filters?? I have not changed the filter since I had owned it and as for diesels I do not work on them much. Not even sure how to change them and them bleed the air in the system.
Also any body know the filter numbers?? I figure if I can get out I should replace them and also get some more fuel since it is down to half a tank
Thanks
Thanks
