Farmall 140 hydraulics issue
tracy h
New User
Need help when tractor get to operating temperature the hydraulics
Will bearly pick the disk up. It running at 180 degrees is the right
operating temperature? The hydraulics is coming of high pressure the
only thing that I can think of is the fuild is get to hot I have no way to
check flow rate
My thought is the pump is worn out.As they wear the 'tolerances' get larger and the oil gets thin as it warms up. About the only way to 'fix' is to replace the pump.However,testing is a good idea,if you can.My 'old' 706 with 13,000 hrs is getting that way too.
If the fluid is new Hytran, ignore this. New oil can have much more stable viscosity than old oil. It may be possible to use a combination of Hytran, and 30wt non detergent engine oil to keep it operating. If this system is never connected to remotes, putting a blend in it will not contaminate other tractors. Jim
