Farmall A-91 hand lift plow
I am missing two parts for me A-91 plow, and need to find their dimensions to replicate the. I am missing the raising lever push link and link sleeve, rference numbers 6 and 11 in the diagram. All the other parts are there, so just need to fabricate the missing pieces. Looking for overall lengths and diameters of the components. Thanks
they would be the two long horizontally positioned pieces in the diagram; long rod with an elbow, and a piece of pipe with a clevis welded on the end. Sorry the pic didn't upload very high quality.
the long rod with 90 bend on the end hooks to the lever assy and does raise plow just make it long enough and lower the plow after its installed inside the clevis pipe end pipe clevis end length was around 16-18im long if I remember where is the lifting help spring I don't see it on the diagrahm. Lift and block the plow in its uprite position then the measurements of the clevispipe end and rod could be easy measured with lever in its forward lift position
I had the same problem. had to do the same thing as gene said to do. you may find the right parts but youll end up buying a bunch more parts then you need. Bob
Pembroke:
Pieces 6 and 11 in the diagram.
looking for the rod diameter, ID of the pipe it, and the thickness of the flatstock that the clevis is attached to.
Part-11 is 1 inch in diameter & 15 inches from end to end of
clevis. Approximately 8 inches towards the clevis is solid bar
to allow other part to push against. Part-6 is 3/4 inch diameter
and 27 inches long.
