Trent Couch
This is a technical question for all you Farmall folks that have
tried this but will a Farmall SM pilot bearing fit onto the shaft of
a Farmall M. I have a Farmall SM input shaft that fifth gear
slides onto for engagement and a Farmall M upper sliding
gear shaft and to mate these to together I know I need the SM
bearing to fit in the input shaft. It is my understanding that the
SM bearing was bigger in diameter but just wondering if the
inside diameter of the two is the same?
Thanks,
Trent
Thanks,
Trent
