IH planter plate
A steel 'factory' plate will have the factory part number. A plastic plate will it's own numbering system. IH uses a 'C' code. JD uses a 'B' code. I have never see a plate with both numbers on it.Most(if not all) plastic plates are made by Lincoln ag products of Evergreen Colorado.
Dave i have two cast iron plates i will give you, if you can make use of them, but not home now, i will be in about 40 days. There at least a 16 cell plate with the number casted in them, Pretty sure there IHC plates.
I'm not sure what you are asking when you say "all numbers and plate sizes on one plate. I am assuming we are talking about the old common IH steel planter plates.
In general, the planter manual provides a listing of plate part numbers and cell dimensions as well as type of plate (corn, bean, etc.).
JD has a separate manual for the plates, but I don't know that IH does. I could be wrong.
I have an IH plate which actually has all the different sizes on this one plate the one cell for each kernel size plus lists the part numbers for each sixe
