DaveBN
- Location
- Western lower Michigan
I have my governor apart and need some help. The pin at the front that rides against the housing was stuck and I needed vice grips to get it
out. There is only one pin which is frozen to the spring. I have cleaned that up and it slides in and out freely now. Shouldn't there be two
pins? Been awhile since I had one apart.
Also the rockshaft is catching on the pin below it which seems badly worn. Is there a good way to fix that?
Are bushings/bearings/seals for the shafts available to repair the slop in the governor shaft and speed change shaft? Gene B had a solution
for some of this but I don't remember it.
I will call my local dealer in the morning to see what I can get but would like some ideas from you all too.
Thank you
Dave
Thank you
Dave
