B front transmission bearings and seal
jkmdg84
I am looking to replace the front tranny seal and top and bottom shaft bearings. In reading previous posts similar to this project, I should be able to split the tractor at the front of the tranny just enough to disconnect the driveshaft all while keeping the other end of the shaft still inside the clutch, correct? What am I going to need to remove the top bearing and countershaft bearing? Will I need to press the new bearings in? Thanks for the help!
Just split it and pull apart. let the drive shaft come out of the clutch. then just roll it back to gather. you can guide the shaft back into the clutch its not hard at all. it is a 2 man job. Bob
