flhr62
PTO is not working. Finally got the plug out from the bottom of the pto valve. It didn't fall out and is moving up and down when I work the lever. Took the top link hitch cover off and the shaft going to the pto is turning with the tractor running. Need to get a fitting to hook my gauge up to pressure test. When I do that, is there a way to determine whether it's the pump or the valve. If I've missed any thing else please let me know.
Pull the pto out sound like the clutchs are out or the Teflon
rings are bad there is a snap on the shaft that shaft keep the
piston coming out to Far Anyway the PTO will have to come
out
