Farmall H and F30 Diesal
fred goodrich
Just had to bring these two home from the auction! Sure would of liked to have that M.
(quoted from post at 13:21:45 02/18/18)
Didnt know there was a f30 diesel. Awesome did someone make it or is it factory built?
Definitely NOT factory!
Perhaps a Detroit 2-71 transplant?
I knew about the Shepard diesel conversion for the M, but this is the first I have learned about any conversion for the F30 or the H.
It never made sense to me that ANYONE would offer a diesel conversion for the M, because if you wanted a diesel in an M, you simply bought the MD.
its a modern conversion. the WD40 McCormick was the only diesel tractor around in that era. Farmall had nothing till the next series came out with the farmall M diesel
Do they run at the correct rpm? Would you still be able to run the pto at the right speed while maintaining equal power to the stock motor?
