Farmall H carb parts
8850dave
Where can I find a carb kit that does not contain a neoprene needle also need the plug that goes into the bottom of the bowl ??
(quoted from post at 16:41:24 02/15/18) Where can I find a carb kit that does not contain a neoprene needle also need the plug that goes into the bottom of the bowl ??
You will not find a kit with a steel needle valve. Those have been obsoleted. The viton tipped needle valves are SO much better.
I have good luck with these but never tried one in a "H".
https://jimsgarage.wordpress.com/2006/09/14/the-grose-jet/
The viton tip needle came in IH parts system after the 4 & 560's were introduced in 1958. That larger fuel tank apparently put a bit more pressure on the needle and we had constant dripping carburetors on new tractors. The original viton tips were very good but the ones in last years have been more troublesome. Also, the hole in the seat is questionable on many. Some you can even see with the naked eye that are egg shaped.
