Farmall C Sidedresser throw out
I have a 48 C with a C220 corn planter and sidedresser. I am missing some pieces for the fertilizer drive and throw out linkage. Does anyone have any pics of the drive sprockets and linkage so I can figure out what I am missing? Thanks
Bob, I have a 220 mounted on a 1950 C and also one on a 1945 H
I do have a manual and I can take pictures if you need.
Can you give a little more detail of what you need. Thanks John
https://photos.yesterdaystractors.com/cgi-bin/gallery/gallery_pic.cgi?pic=http;//photos.yesterdaystractors.com/gallery/tphotos/a139635.jpg&firstrec=26&Parameter=oldiron29&w=tphotos&cc=1&s=
Thanks John, I have the sidedresser mounted but I am missing the whole throw out assembly and the drive sprockets that are on the tractor I believe are not the correct ones. If you could take some pics of your setup on the C I would really appreciate it! I am trying to find these parts I would like to use it this spring. Thanks Bob
http://www.ihpartsandequipment.com/implement-parts/
Duffield Equipment 717-552-1951 ask for Mike, He was a big help to me in locating parts and such. He knows a lot about IH implements.
Bob, Do you have the shaft coming out of your brake cover? If not I see there is a pair for sale on EBay. No sprocket or clutch drive.
If you call Mike Duffield he will know where he can get the parts, he has more than is on his web site.
John, thank you for the pics that is exactly what I was looking for. These are the sprockets on my tractor. They look like they go to a Super C but they were on it when I got it. I'm not sure if they will work or not. I will try this week to give Mike Duffield a call
Bob, What I think you have is the check row mechanism for the planter, I think I have one of those in the shed. I will check in the morning.
The Shaft is correct, you just need the clutch, sprocket and activation rod.
Bob, Just looked through my PLA-3A no pictures of the drive unit on a C mostly H and M, A and B
The farmall C must be in a different manual.
Thanks for checking John , this is a check row planter. It has the same clutch and sprocket on both sides. The check row reel only uses the left side drive. It looks really similar to what should be on a Super C. I'm not sure if they are interchangeable or not maybe Mike Duffield will know. Thanks Bob
Bob, I think these are the arms that mount on that little bracket above the shaft. I have a pair R and L
rod about 30" long. I am not sure how a super C with disc brake would have set up?
<image src="http://forums.yesterdaystractors.com/photos/mvphoto10954.jpg"/>
John, I believe those are the parts I need. Are you interested in selling them? My email should be available on modern view. Thanks Bob
