I have a Case IH 585 that broke the fitting on the end of the steering cylinder rod. I replaced the fitting and it would barely turn left but would turn full right just fine. When turning left the cylinder rod will extend and break the fitting when it bottoms out. After braking and replacing the fitting again it will not turn left at all. It still turns full right fine. When turning the steering wheel left the cylinder rod extends but the front wheels don't turn. Someone on the Case forum said the piston on the cylinder rod has moved and must be taken apart and pressed back to center. Any help will be appreciated.
