TractorLinks.com
Show Parts for Model:
Rebuilding an H Transmission on the Tractor.
Oregon Tractor Jack
02-12-2018 16:35:47
I think I know the answer, but here goes. Can you rebuild the transmission on and H with out splitting the tractor? I know you need to pop the top to get to the gears, but I don't see any reason to split the tractor. Opinions or experience?
OTJ
fbh44
02-12-2018 23:11:24
 Re: Rebuilding an H Transmission on the Tractor. in reply to Oregon Tractor Jack, 02-12-2018 16:35:47
I found it real easy to rig pulleys and rope and lift the top right straight up to the ceiling joists. Leave it there, and then lower it down. Thing's heavy for an old man.
Oregon Tractor Jack
02-12-2018 18:20:24
Thanks, that what I thought. I am working on an H puller and I want the gears and ring and pinion out of a W4 I have sitting here. I didn't want to have to deal with two tractor "explosions" to get it done. Shop space is at a premium anymore.
OTJ
Janicholson
02-12-2018 19:24:54
 Re: Rebuilding an H Transmission on the Tractor. in reply to Oregon Tractor Jack, 02-12-2018 18:20:24
The ratios are taller (faster per gear) than an H. Is the engine tweaked enough to power higher ratios? Jim
oregon tractor jack
02-14-2018 19:55:24
 Re: Rebuilding an H Transmission on the Tractor. in reply to Janicholson, 02-12-2018 19:24:54
This will be for a pulling tractor. I want the higher speed the ring and pinion will get me.
OTJ
Zachary Hoyt
02-12-2018 17:53:43
I took the H gears and shafts out of my H and swapped in a Super H set several years ago, without splitting the tractor. I dropped the Liftall and removed the top deck. If you have a way to hang the steering column off the ceiling or a frame or something it saves a lot of work to just pull it up enough to be out of the way without disconnecting the controls. Zach
sflem849
02-12-2018 17:52:25
No need to split the tractor. It is really easy once you get the top off.
