Hydraulic for Loader on 856
JWCarp
Is there a place on an 856 to pick up hydraulic from the main pump for a loader. I currnetly have the loader running off the aux valves but I can't do that and have the loader hooked up at the same time. I am hoping that there is someplace on the valve spools under the seat to run to another set of valves that I can mount on the loader. Then I can have the valves for the loader and the regular aux valves for the baler. Thanks for your input.
(quoted from post at 13:25:58 07/20/12) Is there a place on an 856 to pick up hydraulic from the main pump for a loader. I currnetly have the loader running off the aux valves but I can't do that and have the loader hooked up at the same time. I am hoping that there is someplace on the valve spools under the seat to run to another set of valves that I can mount on the loader. Then I can have the valves for the loader and the regular aux valves for the baler. Thanks for your input.
There probablu is, but why? It takes less than 10 minutes to drop that loader off and then it is totally out of your way. That is the reason quick-attach loaders were designed.
Not to be a smart donkey, but what type of loader do I have? I have a IH 2000 loader and it takes me more than 10 minutes to take off. Thanks for the advice though.
You can put a "power beyond" plate on it.then you will have live hydralics fully independent of the valves.
Thanks. Looks a little pricy with buying another #1 valve and the powerbeyond plate. Sounds like a good project for the spring. Thanks again.
Is the #1 valve on an IH 856 on the left side of the tractor or the one on the right?
Do you have any pictures to show how to add on the power beyond plate and plumb the tractor for loader valves?
thanks, dirtyoily
